Order Ford 9N Parts Online
9n Governor Gear
9NCharlie
09-02-2005 06:08:19
I have searched the forum, but no answer was found.
My 9n governor gear is free wheeling on its shaft.
How does the governor gear attach to the shaft?
Thanks, Charlie
Bob
09-02-2005 14:16:40
 Re: 9n Governor Gear in reply to 9NCharlie, 09-02-2005 06:08:19
If it is just loose, not really worn "sloppy", try cleaning it up (degrease thoroughly), then use Loctite Primer, followed by Loctite High Strength Bearing and Sleeve Retainer.
Of course, you may be able to find another unit for the price of the Loctite producte mentioned!
don b
09-02-2005 14:12:18
Charlie..... it is a press fit.Gear or shaft or both will need to be replaced. don b
