Order Ford 8N Parts Online
ReBuilding 8n Oil Pump
RBCanada
09-02-2005 15:18:26
How do you remove the Large Gear from the pump shaft? How do you remove the Small pump gear off the shaft? I"ve got my pump apart and it looks like the shaft bushing is worn out because there is a fair bit of play between the shaft and the housing.
Scott PA
09-02-2005 17:21:27
 Re: ReBuilding 8n Oil Pump in reply to RBCanada, 09-02-2005 15:18:26
It is a tight fit but it should pry apart, if the shaft wobbled any it is no use rebuilding it because the small gear wore into the housing inside that is not rebuildable with parts, you can buy a new housing with the bushing already in and a new gear kit and have great oil pressure even when hot running at idle, measure the small gear width when you go for parts because there were 2 different ones and you must get what was in before or your oil pickup will not be at the correct place.
