PTO Shaft conversion
Pooh Bear
09-02-2005 19:43:38
I took my ORC off yesterday to inspect it.
The internal splines are wallered out bad.
That was why it was wobbling so much.
So I have to replace it.
The PTO shaft didn't look bad.
It had some wear on it, not a lot.
I'm wondering if I should go ahead and replace it now.
I looked at the PTO shaft conversion on this site.
Was about $105. Is that all I need. Do I need any other parts.
Then I will also get a new ORC to go with it.
Thanks.
Pooh Bear
1949 8N front mount
DaveH(NY)
09-03-2005 11:21:23
 Re: PTO Shaft conversion in reply to Pooh Bear, 09-02-2005 19:43:38
Pooh, go ahead and make the change and get the new ORC to match it. You don't need any additional parts just make sure you drain the hydraulic fluid or park the tractor with the nose down hill.
Pooh Bear
09-03-2005 12:47:58
 Re: PTO Shaft conversion in reply to DaveH(NY), 09-03-2005 11:21:23
Do I just need the conversion, Part No: 9N700-38
Or do I need to order any other parts to do this.
Thanks.
Pooh Bear
ChrisH(IA)
09-03-2005 12:56:25
 Re: PTO Shaft conversion in reply to Pooh Bear, 09-03-2005 12:47:58
That's all you need----You can make a gasket outta an empty cereal or detergent box if the old one is split. ChrisH (IA)
Pooh Bear
09-03-2005 15:09:20
 Re: PTO Shaft conversion in reply to ChrisH(IA), 09-03-2005 12:56:25
Thanks. Gonna do this sometime this week.
Pooh Bear
