Rebuilding TSX 241 B carb. Am using Don's online carb guide, but have questions on which jet is which since I had to drill out 2 jets. I have the economizer jet in place. Of the two remaining jets, I'm guessing that the one with the smallest offrice is the idle jet and the one with the larger offrice is the main jet. Is this correct? I have tentatively installed the idle jet and it screwed in with no problem. I have looked high and low for the main jet and can not find one on this carb. Is the main jet in the bottom of the hole where the nozzle goes? In the bottom of the carb there is a hole, but it looks to just be a drain hole above the sintered plug. In the back of the carb (other end fro the air inlet there appears to be a brass circular fitting pressed into the bottom. It would be where the high speed needle tip rests. It seems smaller that the main jet in the kit and doesn't appear to have any screw slot. There is no jet in the bottom of the carb through the retangular hole (as shown in the pic). Any help is appreciated. I'm trying to get this back together tonight. Thanks.
