brakes, or more specifically oil leaks
Rango
09-03-2005 10:23:27
Inner seals??Now I am lost. I am thinking my early 8N was not equipped with inner seals. It was suggested I make a half moon dam, sounds feasible but where, and how? I am assuming some light sheet metal cut to barely clear the axle and covering the lower part of the axle housing. Any additional help would be great. I dont really want to be taking it apart again soon if I can help it, those darn tires are heavy.
hvw
09-03-2005 12:16:04
 Re: brakes, or more specifically oil leaks in reply to Rango, 09-03-2005 10:23:27
Try this site for tips on getting the axles sealed up. Worked perfect on mine,
Rango
09-03-2005 14:43:38
 Re: brakes, or more specifically oil leaks in reply to hvw, 09-03-2005 12:16:04
wow, the Joe smith site is a great help. lots more detailed advice than is in the manual. thank you.
Jerry (AL)
09-03-2005 11:13:46
ALso, need to make sure you aren't over filled on the oil. Should be below the bottom hole on the inspection plate. I've never been into where you are talking about so won't try to help you there but someone else will come along here. Mine was leaking a liilt though and I drained the oil down to the bottom hole and it stopped.
