STEERING ADJUSTMENT
RAVI
09-03-2005 10:58:19
I AM TRYING TO SET THE ALIGHNMENT ON MY 52 8N. WHEN THE STEERING WHEEL IS STRAIGHT THE WHEELS POINT STRAIGHT, BUT WHEN I TURN THE STEERING WHEEL ALL THE WAT TO THE LEFT OR RIGHT THE SPINDLE STOPS HIT THE LOWER PART OF THE AXLE. DO BOTH SPINDLES HAVE TO HIT THE STOPS AT THE SAME TIME. LEFT OR RIGHT ? HAS ANYONE DONE A ALIGHNMENT ? THANKS
ZANE
09-03-2005 13:09:09
 Re: STEERING ADJUSTMENT in reply to RAVI, 09-03-2005 10:58:19
The spindle stops are designed to prevent either wheel turning too far either way. One or the other may make contact before the other but it doesent matter as it still is preventing a wheel turning too far.
The only alignment you can make is to set the toe end which is about 1/4" closer between the front wheels at the inside front of the tires.
Steering gear lash is adjusted by loosening the jam nuts on the individual steering pitman shafts and tightening the mesh of the gears with the set screw and then re tightneing the jam nuts. Adjust the pitman shaft that is against the ball nut gear on the sector shaft first and then the other one.
Zane
ozark mike
09-04-2005 04:50:40
 Re: STEERING ADJUSTMENT in reply to ZANE, 09-03-2005 13:09:09
Zane what size is that jam nut....mike
ZANE
09-04-2005 05:17:46
 Re: STEERING ADJUSTMENT in reply to ozark mike, 09-04-2005 04:50:40
I believe it is 9/16"
Zane
uh . . . Dell (WA)
09-04-2005 09:25:45
 Re: STEERING ADJUSTMENT in reply to ZANE, 09-04-2005 05:17:46
Mike..... ....the 1949-52 8N's steering gearbox gearmesh adjust jam-nut is 7/16-20, which would normally require a 11/16 wrench..... ...Dell
ravi
09-03-2005 14:21:04
thanks zane.
