Order Ford 8N Parts Online
Yellow 8N
Robert8N
09-03-2005 14:37:40
When I got my 8N and started sanding got down to a yellow paint. Looks like the yellow used by PA DOT workers equipment. Looks like it came from factory this way. Anybody every have one like this? Was it used by road crews? Thanks
Robert8N
09-03-2005 22:12:28
 Re: Yellow 8N in reply to Robert8N, 09-03-2005 14:37:40
Thanks for replies everybody. I did find red paint under the yellow. The rear tires were loaded and the front engine pulley had one of those adapters for a PTO shaft to fit in so maybe it had a front loader or power broom. The engine doesn't have the serial numbers so must be a replacement. Figured it must have been used for road or some industrial use. Thanks for the info.
Coldiron
09-03-2005 20:53:31
My 51, Ol Yellar was bought from a JD dealer that got it in trade from a county road dept. It came with a Wagner WM3 loader with weights, loaded rear tires, a dearborn brush hog and a back blade. Everything was yellow. I have read that Ford would send some out painted yellow to govt agencies, prisons, road depts, etc. She is about to go to Gray and Red this winter.
Bob Lefler
09-03-2005 19:16:21
My 48-8N has a yellow lift, but the rest of the tractor is standard. Bob
JohnJ_PA
09-03-2005 18:46:20
My 8n was yellow when I got it...but there was the orignal red color underneath the yellow paint. See pics. -JohnJ
Tim PloughNman Daley
09-03-2005 14:58:00
Yes, many public municipalities bought N "s for highway use and painted them safety yellow. They did not come from the factory like that I"m sure. Yellow painted tractors/equipment would"ve been a dealer function, either painted by them or outsourced down the road to a bump/paint shop. hth
TD
Rob
09-03-2005 17:28:20
 Re: Yellow 8N in reply to Tim PloughNman Daley, 09-03-2005 14:58:00
I wonder if the airport tugs were painted yellow.
rurlndum
09-04-2005 08:11:08
 Re: Yellow 8N in reply to Rob, 09-03-2005 17:28:20
There is an old airport tug in our area that is yellow. It also has a two speed rear differential.
