Order Ford 8N Parts Online
8N quit moving
Robby H
09-05-2005 18:44:34
8n quit moving while in gear but is still running
DavidO
09-06-2005 03:52:00
 Re: 8N quit moving in reply to Robby H, 09-05-2005 18:44:34
If you have a Sherman transmission, check to be sure that it did not jump out of gear.
Rick H. Ga.
09-05-2005 19:04:25
Does it not move in all gears? Did it make a strange noise when it stopped pulling?
Possibly bad clutch, broken drive shaft coupling or broken/sheered ring gear. HTH. Rick
Robby H
09-05-2005 19:22:44
 Re: 8N quit moving in reply to Rick H. Ga., 09-05-2005 19:04:25
No it does not move in any gear. It did not make any noise. Thanks for answering so quickly.
Rick H. Ga.
09-05-2005 19:32:55
 Re: 8N quit moving in reply to Robby H, 09-05-2005 19:22:44
Check and see if the PTO is turning when engauged; that will confirm your clutch is good and the counter shaft in the transmission is turning. The drive coupling is located under the lift cover in the center casting. Someone else may have a better suggestion, but you can remove the lift cover and check both the drive coupling and the ring gear. HTH. Rick
