53 NAA Hydraulic Problems
ryanNva
09-06-2005 07:14:49
53 NAA. I was lifting something up and the hydraulics bound up and fluid leaked out from my pump. Now the hydraulics go up and down, it jumps going up and when up, with weight on it it slowly goes down. I'm wondering what my problem may be. The fluid leaked out from the pump, maybe round a seal in the middle of the pump. When it cools down i'll check the level and see if some needs to be added. but i don't think that is the problem since only about a half a quart leaked out. Any thoughts, ideas
Ramrod
09-06-2005 08:49:06
 Re: 53 NAA Hydraulic Problems in reply to ryanNva, 09-06-2005 07:14:49
Dan is right, but before you do that, just open up the hyd filler hole and peek inside with a flashlight. If there is trouble with the cylinder or valve body, you will see the leak there. If you have a leak, it will be time to pull the cover. have you got the pump leak fixed? Which type pump do you have?
Ramrod
Dan
09-06-2005 07:41:43
There are too many variables to point you in the right direction with the info we have available. Remove both inspection plates (put a pan underneath to catch any oil), start the tractor up, put a heavy weight on the lift arms, and raise the weight. Look inside the inspection holes with a flash light and see if you can see any squirting, swirling, or streaming fluid - and where. Concentrate on the open end of the hydraulic cylinder, around the valve plates, and the internal pipe that carries the fluid to the lift cover. Report back with your findings and we should be able to point you at least in the general direction.
Dan
ryanNva
09-06-2005 07:15:19
The Fluid level is okay, within its limits.
Ramrod
09-06-2005 08:54:54
 Re: 53 NAA Hydraulic Problems in reply to ryanNva, 09-06-2005 07:15:19
I looked back at the earlier thread and see that you do have a piston type pump. If that is still leaking, you need to start there. You can rebuild that pump with common tools and about $100 (in CNH parts)to get it back like new. If it is just the o-rings that connect the lines, replace those with new ones from CNH and let's move forward. What did you see looking through the hole at the cylinder/piston?
Ramrod
