Order Ford 9N Parts Online
9N Valves
Roger 9N
09-06-2005 09:24:29
One more post on this. If you take off the manifold, remove to 2 square valve covers, and turn over the motor:
1) Shouldn't you be able to see some movement of the valve stems and springs ?
2) The piece at the bottom of the spring that is about an inch in diameter, does that move up and down with the valve ?
Dell (WA)
09-06-2005 10:43:11
 Re: 9N Valves in reply to Roger 9N, 09-06-2005 09:24:29
Roger..... ...the camshaft lobes only have about 1/4" lift. The lobes directly lift the tappets, therefore the tappets will lift the same amount that the lobe lifts, about 1/4". The valve assembly is springloaded to extend down to the tappet (except for 0.016" valve clearance) When the tappet lifts, it will contact yer valvestem and lift the valve.
The valvestem spring keeper (1" shiny disc) will rise with the end of the valvestem. ...unless... the valve spring keeper's have been "un-locked" from the end of valvestem. Iff'n "un-locked" the valve spring won't pull the valve backdown into the valveseat and you will have NO COMPRESSION.
Howsomevers; sometimes sticky valvestems inside the valve guides can overcome the valvespring pressure and keep the valve open and you will have no compression eather. This is why you were recommended to wash yer valve assy's with MMO.
So bottom line, yes, you should beable to see the valve stem go up and down iff'n all the keepers are where they're supposted to be. But watch the tappets first, then the valvestem ends..... ..Dell
Rob
09-06-2005 10:04:36
Yes and yes. The cam shaft pushes on those 1" round things (lifters/push rods) and they lift the valves. If nothing is moving then maybe the cam shaft is not rotating. Some early models had a fiber cam shaft drive gear, there under the front timing cover. That fiber might strip, the cam shaft will not rotate and the valves will not lift.
