TRACTOR LEVEL
RAVI
09-08-2005 06:18:39
I have put 16 inch passenger tires on the front of my 52 8n, but now the front of the tractor is about two inches lower than the back. Could this be a problem since i will be using this tractor to pull a three point five foot finish mower? The area I will be mowing is mostly level.
Steve IA
09-08-2005 08:36:35
 Re: TRACTOR LEVEL in reply to RAVI, 09-08-2005 06:18:39
With the smaller tires on the front, you'll almost always be going downhill which will save on gas consumption. That's also why dragsters have little bitty tires on the front. They're going downhill all the time and the gravity helps em go faster. I learned all this in fissiks clas. 8-).
Steve
Dubya
09-08-2005 11:10:26
 Re: TRACTOR LEVEL in reply to Steve IA, 09-08-2005 08:36:35
No way you are wrong. Those little front tires will have to spin faster, which means that the front of the tractor will go faster. This is going to stress out the frame something fierce and usually the first thing to go is the pin holding the front suspension to the injun.
Heh, I learned this while I was clearin' brush at my ranch. It's real hard work but I do it to be a man of the people.
souNdguy
09-08-2005 06:29:30
I dn't see any problems. Just get the toplink adjusted correctly.
Soundguy
Doug (OH)
09-08-2005 17:01:36
 Re: TRACTOR LEVEL in reply to souNdguy, 09-08-2005 06:29:30
What is the proper way to adjust the top link anyway; e.g., for a brush hog.
Dell (WA)
09-08-2005 17:39:18
 Re: TRACTOR LEVEL in reply to Doug (OH), 09-08-2005 17:01:36
Doug..... ..since I use the round "turn-buckle" style top-link; I ALWAYS adjust my top-link so I don't haffta fight to put the top-link pins in their holes. Simple, eh?..... ....Dell
