PTO SIZE
RAVI
09-08-2005 07:39:52
My 8n has a 1 and 1/8 inch pto shaft, is there any way to to purchase a coupler that slides over the existing shaft and does not lengthen the pto shaft?
Pooh Bear
09-08-2005 15:03:26
 Re: PTO SIZE in reply to RAVI, 09-08-2005 07:39:52
How much you want to spend?
This site has a kit to upgrade your shaft to 1 3/8 for $105.
I plan on doing this to my 8N in the near future.
Pooh Bear
souNdguy
09-08-2005 12:06:51
TSC sells both a sleave/bushing that increases diameter only.. it's kind of flimsy as another poster pointed out.. but for some situations does the trick. there is also a stub extender that adds about an inch and also bushings the shaft up.. this adapter is much more robust.. i currently have one on my NA.. runs a 5' mower fine.. so far.
They also make an ORC that acomplishes the bushing-up and acts as an orc.. etc.
Soundguy
Rob
09-08-2005 10:40:23
A coupler? If you want to adapt that 1-1/8" male to an 1/-1/8" female then a sleeve will work without adding length. I had a sleeve under an ORC on a really worn 1-1/8" shaft for years before I took the tractor out of service. The sleeve was in three pieces but it do not matter. It is there to occupy space is all and one piece or two pieces or three pieces did not matter because it was all in there. Another couple years I might have replaced the sleeve.
Rob
09-08-2005 10:41:49
 Re: PTO SIZE in reply to Rob, 09-08-2005 10:40:23
Make that "adapt to a 1-3/8" female."
Rick H. Ga.
09-08-2005 07:58:56
I purchased a sleave adapter that accomplished the size conversion with out adding much length as you mentioned, but it didn't last long before it twisted and broke. I then got the long 1-1/8 to 1- 3/8 adapter that has lasted 25 years. HTH. Rick
