53 NAA here that we are talking about. So i got my choke problem fixed and adjusted the carb per Dell's specs and it runs great now, don't need choke 1/2 out anymore.Now on to the questions at hand. In lookin at the right side tire and brakes, the brake is mushy indicating to me it either needs adjustin or new pads. I know there is an adjustin thingy on the back side under the fender area with a screw thingy that has to be turned, but much to my dismay it is stuck/froze. I tryed penetratin oil and no such luck. I'm thinking the only way to make sure it gets un froze is to take wheel off/hub assembly off/drum off and actually look at the brake and adjust it that way. Now, my tire seems to be stuck, i've put penetratin oil on, using a big honkin socket and breaker bar, i slipped a long piece of steel pipe over and tried to use leverage but it didn't work. Any other thoughts, also, i'm not sure what direction, is it righty tighty lefty loosen or the opposite?? I know on some old tractors they used a reverse thread on these. thanks in advance.
