oil pump
00fxd
09-12-2005 11:08:37
Hi All,
I have now recieved my oil pump kit. 1 question.
How is the gyrotor gear removed from the shaft? Mine seems to need to be pressed, but I prefer not to press againt the oil pump housing.
Thanks, Frank.
Rick H. Ga.
09-12-2005 12:41:22
 Re: oil pump in reply to 00fxd, 09-12-2005 11:08:37
Hi OOfxd,
I admire you for wanting to rebuild your oil pump yourself, but most folks take it to a machine shop or tractor dealership service department and let them rebild it for that very reason. You will need a press and a reaming tool and a micrometer to check the clearences. HTH. Rick
00fxd
09-12-2005 14:37:47
 Re: oil pump in reply to Rick H. Ga., 09-12-2005 12:41:22
Thanks Rick,
My bushing/shaft is in very good condition & has no play so I feel that a gear swap will do the trick. The gears show some wear. I do not have an engine machine shop in our small city. Frank.
