Float setting
RustyFarmall
09-13-2005 13:57:10
Nope, I'm not on the wrong board, just need a little info. I am rebuilding a couple of TSX 33 carbs. I have found the info I need for initial settings, as well as the float level, but no mention is made of what the float drop should be. Is it not critical on these carbs? Anyone know what it should be?
Rob
09-14-2005 03:54:51
 Re: Float setting in reply to RustyFarmall, 09-13-2005 13:57:10
I hope it is not critical because I never saw a spec and do not check it. I do make sure the float is level at 1/4" and that works good.
RustyFarmall
09-14-2005 05:01:13
 Re: Float setting in reply to Rob, 09-14-2005 03:54:51
Thank you, like I said, I easily found the 1/4 inch spec, but nothing for the drop. Guess I won't worry about it.
Tom in MS
09-13-2005 16:00:56
Check this out Link
