Order Ford 8N Parts Online
8N 3 Pt hitch has NO power
Robb
09-17-2005 10:08:35
I just got my first tractor recently
The 3 pt hitch will lift about 100lbs
That's it !????
Questions
What goes wrong?
how expensive $ to repair?
What oil is used?
Is this the same oil for the transmission?
Sat 17th at 1:15pm
Thanks You
Robb
Syracuse NY area
guest
09-18-2005 04:13:16
 Re: 8N 3 Pt hitch has NO power in reply to Robb, 09-17-2005 10:08:35
If you just bought it I would
drain the hydraulic oil from the
three chambres ( be prepaired to
catch 5 gallons).
See how much comes out...
Put in 4.5 to 5 gallons of 80-90 wt
oil or 134 (light weight oil) and try
again.
You might just be low.
George
JeremyS
09-17-2005 10:53:58
Hi Robb. Mine did the same thing, only wouldn't lift even 100 pounds. My valve chambers on the pump were cracked due to water in the oil. Once it freezes, they can crack and cause the pump to lose alot of pressure. The tranny/hydraulic/rear end all use the same oil to run and lube everything. 5 gallons all together. Can't say for sure what your problem is, but pull the inspection cover on the right side-it has the dipstick in it, and with the hydraulics running look in with a light and try to see if you can find a stream of oil shooting from somewhere. It may also be a badly warm lift cylinder which is above the pump. Where around Syracuse are you? I live in Hannibal and work in E. Syracuse.
aussie Rob
09-17-2005 19:25:51
 Re: 8N 3 Pt hitch has NO power in reply to JeremyS, 09-17-2005 10:53:58
Thanks for that info. I will do that on Monday.
I'm 20 min south of Syracuse just past Tully but before Cortland
My sleepy hollow is at Little York.
Hey my big hobby is WW2 Jeeps and early CJ2a's
I have 3 Willys war jeeps, with one on the road.
I have two Willys PU trucks woith one on the road as well.
In fact If you're looking for a fun day.
Tomorrow, the 18th. our local chapter of the Mil Veh Preservation Assoc. has an all day BBQ in our back yard.
We live next door to a large'ish county park - Dwyer Memorial Park, in Little York, NY
Tomorrow is a huge Cortland Antique and Classic Car show and flea market.
If you'd like to come with the family or not... for a fantasic day. send me an email to aussierob2@odyssey.net or call 607-749-2628 and leaqve a message ... we'll soon get back to you
If the sun is promising... then we could have as many as 20 old Military Vehicles.
You are welcome.
We hold this day for our summer picnic to coincide with theh=ir car show! The Park will have a couple of hundred booths selling everything you can imagine.
Thanks for the info... do you know any approx prices for the pump or Cyl repair for tthe kit parts.
I would try and repair at home @
Best e'gards,
Robb
