dearbourn snow plow
Ravi
09-17-2005 21:33:23
I have a front mount dearbourn snow plow. does any one know how far to space the front brackets.
Upper Peninsula,MI
09-18-2005 19:40:35
 Re: dearbourn snow plow in reply to Ravi, 09-17-2005 21:33:23
Ravi. There are a couple of different Dearborn snow plow set ups. Mine has the frame attached to the rear axles below each rear fender.Others attach about half way back from the front. My instructions are 60 miles away at camp, however as I remember the front wheels should be pulled into 48 inches, which I believe is the way they came from the factory. Then install the front brackets and they will be set right. Do you have any literature or brochures for it? If not email me and I'll see if I can find mine in the computor and get a copy to you. Good luck. Ron
