Jubilee
Lift stuck in up position
Patrick-OR
04-16-2001 14:32:26
I had a weird thing happen. While mowing with my Jubilee, the lift stuck in the up position. After putting the lift control in draft mode and moving the control arm up and down a few times, it came down and worked properly the rest of the day.
Does anyone have a clue what may have happened and if I should be worried?
Thanks in Advance!
Patrick
ZANE
04-16-2001 19:22:14
 Re: Jubilee - Lift stuck in up position in reply to Patrick-OR, 04-16-2001 14:32:26
The control valve probably stuck. Their is no filter in the hydraulic system of the Ford tractor and sometimes a little particle of foreign material travels to the control valve and will cause it to stick.
