Hydraulic leak down
Randy's 8N
09-19-2005 10:40:08
The hydraulics on my 1947/8 8N will drift back down to the ground in about 45 minutes with a 250lb load (no not me...). A little erratic/bumpy on the way up. I'd like to replace the piston in ram with NAA o-ring piston. Which valves down in the pump should replace while i'm in there? thanks.
Dell (WA)
09-19-2005 11:29:58
 Re: Hydraulic leak down in reply to Randy's 8N, 09-19-2005 10:40:08
Randy..... ....yer hydraulic's will hold for 45-min's? thats "braggin' time".
Ain't 'nuttin you've said to incidicate enny sorta valve problems. Iff'n ain't broke, don't fixxitt.
Yes, the improved NAA "O-ring" piston replacement for yer old 3-ring hydraulic piston is a "good deal". Worth the effort.
Also inspect yer 8N's position control cam PIN. Lotta info on replacing it, check archives..... ....Dell
