1953 jubilee
ralph john
09-19-2005 10:41:28
i still have not found the ser. # that is hand stamped above the starter on a flat
Ramrod
09-19-2005 11:21:19
 Re: 1953 jubilee in reply to ralph john, 09-19-2005 10:41:28
I didn't find mine until I sandblasted, and then there it was, right where it was supposed to be. It is a very dim and shallow hand stamping, and easily obscured by paint.
Ramrod
Dell (WA)
09-19-2005 11:00:46
third party image
Ralph..... ...according to NAA Dan Dibben's most excellent site>Link
Golden>Link Jubilee and NAA Ford tractors: produced from 1953 to 1954
On early production models, before serial number NAA-22239, the serial number is located on the left front corner of the engine block, just below the manifold. On models serial number NAA-22239 and beyond the serial number is located on the left side of the transmission housing, above and to the rear of the starter, just below a 3"x 6" horizontal flat on a 3/8"x 3" semi-vertical surface. The serial number is hand-stamped onto the semi-vertical flat, not cast into the transmission housing. Format is model designation (i.e. "NAA" or "NAB") before sequential production number.
HTH..... ...Dell
Dan
09-19-2005 10:56:56
The very early models had the serial number stamped on the upper left side of the engine just behind the carb. linkage towards the front of the engine. Check there.
Good luck,
Dan
Leemo
09-19-2005 10:47:15
I never found a serial number on my Jubilee either. Replacement engine block possibly ??? Not sure what the deal is but it just isn't there on mine.
Good Luck, Lee
ozark mike
09-19-2005 12:15:49
 Re: 1953 jubilee in reply to Leemo, 09-19-2005 10:47:15
Leemo,, even a replacement blocks should have an s/n... mike
