1953 jubilee starting how much oil goes into tho
ralph john
09-19-2005 11:56:44
i saw a naa # on the left side of what i call the trans.that could be it. could this tractor ever come from the manufacture in blue as there is a good coat of blue underneath. this tractor seems to need a choking to get it started. i have yet to buy or put in any oil, how does one tell when to change and how much to put in also mix old ans new. has not been run much in the last two yr. i bought a battery & a starter syl
thanks
r.j.
ericlb
09-19-2005 18:06:21
 Re: 1953 jubilee starting how much oil goes into in reply to ralph john, 09-19-2005 11:56:44
rj, i change my jub's oil every 3 months, but mine is a working tractor, that is i use it commercially, to mow, put up fence , blade ect, its also painted old ford engine blue and grey,because the pervious owner just happened to like that color, ive had it over 10 years myself and as they say, its your tractor paint it any color ya like,[ observe the pink jd below]
souNdguy
09-19-2005 12:19:55
At least change the oil once per year.. if not twice a year.. or if it gets real dark or thin.
Crankcase has a dipstick on it for checking the oil level. don't forget to service the oil bath air cleaner as well.
Needing choke to start could be anything from weak sparkies ( coroded connections / bad switch / bad wires.. ) to a dirty/plugged carb, to a vacume leak.
OEM color was red cast metal, grey tin.
You might want to invest in an I&T FO-19 service manual.
Soundguy
Dell (WA)
09-19-2005 12:18:48
Ralph..... ..yer Ford owners manual will answer all yer questions ...or... gittcha an I&T FO-19 NAA Jubilee manual. $22, cheap. Readily available from sponsors of this great N-Board. Many agricultural emporiums. amazon.com, BordersBooks, WalMart books. www.n-news.com also has great archive of 3-point implement manuals. Yer local CNH Ford/New Holland dealer probably sells it, isn't that amazing? Even my local (byte my tongue) John Deere parts counter has it for sale. Squander some beer money an readitt!!!
My Ford owners manual sez to change engine oil every 100 hrs or once a year. I change every fall. Now's a good time isn't it? I use 20-50wt oil in all my vehicles, but thats because I read and understand oil specifications..... ....respectfully, Dell
