jubilee lift
rip
09-19-2005 14:44:19
My 3-point seems to stop lifting after it warms up from use. When it is cold it will lift just fine. After a while it wont lift but I can still hear the pump trying. Is something worn? Iam useing new hollands 134oil. Can I use a heavier oil?
WiCraig
09-20-2005 16:40:52
 Re: jubilee lift in reply to rip, 09-19-2005 14:44:19
Just my 3 cents but I wouldn't use the ford 134 in it. Craig
rip
09-29-2005 14:30:16
 Re: jubilee lift in reply to WiCraig, 09-20-2005 16:40:52
what oil do you use? Im only useing the NH 134 stuff after reading about it on this board.
souNdguy
09-19-2005 17:32:55
The NAA and hundred sereis didn't like that 90wt oil like the N series did. Yo need to find out if you have a leak like at the piston or check valve.. or if it is pump leakage.
Soundguy
souNdguy
09-19-2005 17:32:46
Soundguy
