Broken PTO shaft or the story of sheer pin that didn't!
Andy - Hammond,
04-16-2001 17:29:51
Well gentlemen I am seriously wondering if this 8N is nothing but a yacht at heart or something - I keep pouring $$$ into this thing and now this!
I finished my bushhogging duties today and came back from the local gas escape to hook up my rotary cutter and bring it to the barn.
I connected everything up with patience and safety in mind. Brought the ole' PTO in play to provide slight lift to get my cutter back to the barn (only 100 feet away) and then BOOM BANG BOOM.
The rotary cutter drive shaft broke loose from the PTO shaft and the whole thing was banging and spinning with wild abandon! I immediately shut it down and at least limited the amount of damage (so I thought). Upon inspection the ORC was still connected to the cutter's drive shaft but it had SHEERED most of the splines off of the primary PTO drive shaft on the 8N. (how nice)
third party image
third party image
I wonder why the sheer pin didn't sheer on the bushhog? Everything was done properly and everything was greased properly - I cannot explain what happened. Now I guess I have to replace the main PTO shaft in the 8N? Can someone provide some insight and probable cost for this?
Also, not as if to add insult to injury, I hear some strange metallic grinding noise in the tranny now. (Was in 1st gear when this all happened - but at idle thottle and never even got the hog up to speed) - thankfully. How do I check the transmission. I was able to easy move the cutter back to the barn (no PTO connection obviously) but it sounds different.
Any advice? Cost? Instruction help?
Thanks so much!
Andy
Hank
04-17-2001 08:12:02
 Re: Broken PTO shaft or the story of sheer pin that didn't! in reply to Andy - Hammond, LA WITH PICTURES!, 04-16-2001 17:29:51
What camera do you have? Good pictures!
Andy - Hammond, LA
04-17-2001 08:19:57
 Re: Re: Broken PTO shaft or the story of sheer pin that didn't! in reply to Hank, 04-17-2001 08:12:02
Past pictures were on a Sony Mavica FD-73 - and these shots were done a very old but great digital camera (Epson PhotoPC) - I really like the Sony much better but I have loaned it out to my older sister. (never see that thing again)
Todd, No Dale's hydraulic fluid was like SLUDGE!
He told me that he did not work on hydraulic systems and didn't fix anything in there. Did you look at it? It was creamy and tan and had sludge on the stick. didnt want to go that route! Even though it may not have been that bad. (grin)
Plus mine has ALL original parts that the other one never had. I am REALLY happy with my 8N - the engine is in great shape - I have come to realize that for the $2000 I spent on the one I got in the great condition w/original - I can afford to spend a little on some brand new components to make it last for the next 50 years!
Thanks,
Andy
Never looked at the tranny fluid.........
04-17-2001 09:22:45
 Re: Re: Re: Broken PTO shaft or the story of sheer pin that didn't! in reply to Andy - Hammond, LA, 04-17-2001 08:19:57
..... was still in shock on the asking price, I suppose. ;) I was kidding earlier. You made a great deal on your tractor, and I'm sure the tractor gods are frowning on me now for joking about your misfortune. Stay tuned..... ..
Redbelly1
04-17-2001 07:22:55
Andy,
I know it's too late now, but next time try drilling out the center of the sheer pin. I use standard soft metal bolts and drill them out with a 1/8" or slightly larger drill bit. Drill through the entire length of it.
I've had my 8N for a year now and have replaced two sheer pins. Takes about five minutes.
I'd rather do that than replace a shaft or a gear.
andy
04-17-2001 05:36:34
Andy you got a guy in your town of Hammond LA that rebuilds 8N's and has two that he just refinished, you can e-mail him at: moondog@i55.com
Good luck you got the best tractor ever built, I got two for myself.
Maybe you should have bought one of Mr. Dale R.'s..........
04-17-2001 06:50:48
 Re: Re: Broken PTO shaft or the story of sheer pin that didn't! in reply to andy, 04-17-2001 05:36:34
..... ..this one is starting to sound expensive! ;)
Good Luck!
Todd in DS
Mark B(PA)
04-17-2001 05:07:21
Andy - I had a similar experience with my pto shaft. It was a worn 1 1/8" version that I used an adaptor on. I sheared off 2 of those things and watched my mower's pto shaft club the heck out of itself and everything around it.
So, I bought a new 1 3/8" pto shaft, about $100 as I recall. Parked the N nose down in a ditch so the oil wouldn't run out. Removed the 4 bolts that hold the pto shaft, popped it out,installed the new one with new gasket and I was back in business in 10 minutes
This would be a good time to peer into the pto hole (rear end gears) and look for wear and also to look at the lubricant for age and contamination. Also, the original pto cover will not fit on the new shaft, but some of the replacement shafts include a new cover, although I don't think it looks as nice as the originals.
HTH - Mark
Paul Haas - Pine Island MN
04-17-2001 04:03:31
Andy: I have posted a link to a thread a couple of days back. There is a picture of a couple of ORC's in the middle, but on the right are the 1 1/8 to 1 3/8 adapters that a couple of us have mentioned. If you start cleaning up the mess and find that what we think we see is correct - you have a 1 1/8 shaft and a converter you have 3 choices. 1) buy an updated shaft for $ 85 to $115 depending on whether or not you want a new housing & bearing. 2)buy another adaptor and run as before
3)buy an ORC that converts the 1 1/8 PTO to a 1 3/8 output shaft.
WHATEVER YOU DECIDE TO DO - CHECK TO SEE THAT THE CUTTER SHAFT IS NOT SO LONG THAT IT WILL RUN OUT OF PLAY WHEN YOU HIT A HILL PUTTING THE TRACTOR AND CUTTER INTO A V (when viewed from the side). I could be wrong, but that would appear to be the most likely cause for the failure, and since your land is unlikely to change, will be waiting to do it again.
bg
04-16-2001 21:00:10
I can't really tell too much from the picture, but it looks like the PTO is just a tad short. Has it been cut off a little bit? Anyway, since you're working on it anyway, get a 1-3/8" conversion shaft and eliminate the adapter. The you can use the 1-3/8 x 1-3/8 ORC
oooh bouy . . . Dell (WA)
04-17-2001 00:01:22
 Re: Re: Broken PTO shaft or the story of sheer pin that didn't! in reply to Andy - Hammond, LA, 04-16-2001 20:29:22
Andy..... .dang... I missed out on all the excitement...didja hafta go home and change yer shorts? (grin)
I assume you know the difference between an ORC and just a PTO 1 1/8 to 1 3/8 conversion adaptor? The picture is kinda hard to calibrate my eyeballs on but it don't look like my ORC.
I'm with Bob on this, put a modern 1 3/8 PTO shaft in and a new ORC for your brushog, both are relative inexpensive vs the cost to a new tranny..... ...Dell
Mark
04-16-2001 19:51:18
Give Lynnwood a call he can fix you up. Very reasonable 1-800-724-1080
years of knowledge
CRS in AL
04-16-2001 19:20:58
Hi Andy;
I hope you are in luck. From the looks of your picture, the PTO shaft is not broken. Your PTO shaft had an adapter on it, (for later model yokes) and the adapter is broken. You should be able to get the remainder of the broken piece off.
When you get this piece off, ingage the PTO and try your lift, watch the PTO turn to make sure its not warped, also try driving the tractor to see if you still have the noise that you were hearing. If it all works properly, then all you will have to do is buy another adapter. If you still have a noise in the tranny, ? - Well,not good, you can drain the tranny oil, put the trans. in N. and remove the top gear stick plate and look inside. (Be sure to check the oil you drain out for metal)
Let us know what happens.
Good Luck ----- CRS
ZANE
04-16-2001 19:17:01
From what I can deduct by looking at the pictures it looks like the ORC gave up the ghost. I don't see how this could have done any damage to the transmisson though. Maybe you are just suffering from shell shock!
Is that the retainer pin for the ORC still in the PTO shaft? It doesn't look like the PTO shaft is broken in the picture but not too clear on that point.
04-16-2001 19:12:03
My eyes are old and getting bad but that sure looks like a 1 1/8 to 1 3/8 PTO converter is what disintegrated. You're closer to it and will be a better juge of that than I. The pin that goes through the PTO is not a shear pin. It is there to keep the ORC from sliding off the PTO - there is no shear (supposed to be) possible with that setup. If the cutters shaft was firmly attached to the ORC and the ORC pinned to the PTO the only guess I could make would be that the cutter shaft is too long and forced the ORC forward so hard it broke the pin some time prior to the big bang.
All you can do is try to get the PTO out and attack the noise in the transmission when you see what is left to work with. Just pulling the shaft straight out may be easier said than done.
