What is correct lubricant for distributer cam?
Paul in VA
04-16-2001 18:58:05
I know I'm supposed to smear a bit of grease from time to time on the distributer cam...but what sort of grease and where do I get it?
I presume the answer will be the same for 2N as for NAA?
Thanks,
Paul
Steve(MO)
04-17-2001 18:41:18
 Re: What is correct lubricant for distributer cam? in reply to Paul in VA, 04-16-2001 18:58:05
About 25 years ago (I just calculated that and can hardly believe it's been that long ago) I bought a tube of Lubriplate brand distributor cam grease. Back then, most vehicles like my '69 Roadrunner had breaker point distributors so the stuff was pretty easy to find. I haven't looked lately, because I still have over half the tube left.
Dell (WA)
04-17-2001 00:24:59
Paul..... beau coup years ago, I bought a tiny tube of distributor cam lube, its silicone, still have lots of it. Go to a good autoparts supplier and ask. I'm not a fan of petrolium jelly based lube in distributors as they melt and evaporate and conduct electricity, silicone doesn't..... .Dell
bg
04-16-2001 19:39:37
Keep in mind that you don't need to "smear" much lube in there. A little dab'll do ya. The danger is getting grease or oil slung on the points, which accelerates burning. So, just barely wipe a little on the cam. Vaseline as Zane says is a pretty good choice because it is pretty viscous.
ZANE
04-16-2001 19:08:17
A little dab of petroleum jelly will do it.
