Order Ford 8N Parts Online
1952 8n resistor for hot coil
rangerrick
09-21-2005 16:27:37
just got52 8n ford. has a resistor on top of coil.need to know where the two wires go to.it has been changed to 12 volt.
thank you
old
09-21-2005 18:36:00
 Re: 1952 8n resistor for hot coil in reply to rangerrick, 09-21-2005 16:27:37
Hooking up a resistor one wire/end goes to the switch wire and the other end to the + side of the coil if its a 12 volt system, with a - ground.
jwm
09-21-2005 16:51:53
It's kind of odd to have a resistor on top of the coil. Anyway a resistor doesn't care which wire goes where. Just put one on each. I sure would would check that 12v conversion over closely. I've never seen one like that. James
