oil in tailpipe
pawpawholdme
09-22-2005 14:40:27
will running a 1951 8-n very little,like just starting it and running a couple of minutes or so cause oil to build up in tailpipe?I was told it was bad to just run one a few minutes,i was also told it would fail the plugs.how much of this is true.... thanks Earl
WiCraig
09-22-2005 15:03:13
 Re: oil in tailpipe in reply to pawpawholdme, 09-22-2005 14:40:27
Won't hurt anything. But if you are getting that much oil past your rings, you're not gonna be running it very long anyways. Fouled plugs.
Cargocult
09-22-2005 15:02:47
It is BAD to run an engine a short time. Better to run it for long enuff to COMPLETELY heat the oil, to burn off the combustion By-products. As far as oil-fouling the plugs, depends upon the engine's condition. A engine in good shape should not have any ill effects. However, it is hell on exhaust systems! Corrosive By-products again! CC
guest
09-22-2005 15:00:30
Yes
Should run it till it reaches operating temperature.
15 or so minutes in summer.
George
pawpawholdme
09-22-2005 15:15:05
 Re: oil in tailpipe in reply to guest, 09-22-2005 15:00:30
thanks for the quick respose on my questions...I wen out and ran it up and down the road for about 15 minutes and it was drying out.thanks again guys... Earl
