fuel bowl valve?
ratropia
09-25-2005 05:30:18
49 8N.
I need to replace the washer for the valve assembly. In the master parts catalog it only shows the kit. Is it possible to just buy the washer, I belive that is all I need. It appears that the existing one might be a fabric washer, would that be correct or something someone may have added?
P.S. this is one of the older valves,it has a reserve tank setting on the dial.
Thanks Rick T.
BillM (OH)
09-25-2005 20:38:50
 Re: fuel bowl valve? in reply to ratropia, 09-25-2005 05:30:18
I think you could twirl a length of teflon tape into a rope, wind'er around the stem and tighten down the packing nut - leave the old stuff in there and just add more.
jwm
09-25-2005 17:43:46
I would check at a hardware store or plumbing supply. You maybe able to just pack it tight with some kind of string or cord. James
