Lacks power
art berger
09-25-2005 18:29:46
I recently overhauled an 8N tractor - new distributor - starter wires. However the tractor seems to lack power idles fine but spits when throttled up under a load - any suggestions on fixing this problem?
old
09-25-2005 19:26:41
 Re: Lacks power in reply to art berger, 09-25-2005 18:29:46
#1 is the water pump end of your engine. If front mount the cap has numbers on it that tell you which wire goes to which cylinder.
Dell (WA)
09-25-2005 19:00:44
Art..... ....ya mucked with yer sparkies wired didn't ya?
Check yer firing order, 1,2,4,3 CCW. These old N-Engines are soooo goood that they will start and run on just 2-cylinders, but won't have enny power when you throttle'em up. Thats:
sparkie #1 is connected to nipple #1 at 10 o'clock
sparkie #2 is connected to nipple #2 at...8 o'clock
simple, eh? now PAY ATTENTION 'cuz it gitts tricky here
sparkie #4 is connected to nipple #3 at 4 o'clock
sparkie #3 is connected to nipple $4 at 2 o'clock
therefore firing order is 1,2,4,3 CCW, isn't that amazing?
HTH..... ...Dell, yer self-appointed sparkie-meister
Art
09-25-2005 19:04:21
 Re: Lacks power in reply to Dell (WA), 09-25-2005 19:00:44
Thanks much for the info.
Is Spark #1 closest to the drivers seat or closest to the fan belt?
Thanks again
Rick H. Ga.
09-25-2005 18:53:16
My first suggestion would be to doublecheck the firing order; 1243 (front to back).
HTH Rick
Art
09-25-2005 18:57:09
 Re: Lacks power in reply to Rick H. Ga., 09-25-2005 18:53:16
Thanks much can you give me detailed instructions how to do that?
Thanks
