Question for Dell
Novice 8N Owner
04-17-2001 04:38:32
Dell,
In a previous post you mentioned that you bushhog in 1st and under, and 2nd and under. What do you mean by that?
Thanks,
Todd
Dell (WA)
04-17-2001 11:21:09
 Re: Question for Dell in reply to Novice 8N Owner, 04-17-2001 04:38:32
Todd..... ...my 8N has the dealer installed optional 3-speed (high, straight, under) "Sherman" aux tranny installed between the clutch and the main 4-speed tranny. The under refers to the 3-speed aux tranny being in low range before power goes into the main tranny.
This auxillary transmission was manufactured by "Sherman Bros" and is the most common, there was also an Overdrive 2-speed and a 2-speed Underdrive, and a "Reverser" tranny for forklift applications.
There were several other aux trannys sold and installed in N-Tractors, Hupp was not so common, the rare and fragile Howard was installed after the main tranny for rototilling.
The N-Tractor is too high speed geared for rototilling but it is a 2-bottom plowing fool..... ..Dell
