Order Ford 9N Parts Online
9N Cam
Roger 9N
09-26-2005 05:42:14
What holds the Cam on a 9N in place. I just replaced a worn out Cam gear, and when i turned it over to ensure that everything looked okay, the cam came out about a 1/4 of an inch. Pushed right back in, but I was not sure if it was suppose to do that ??? Thanks
Jeb2N
09-26-2005 07:57:10
 Re: 9N Cam in reply to Roger 9N, 09-26-2005 05:42:14
There is a small sheet metal disc that fits between the inner recessed circle and the inside face of the timing cover. It's a little disc with a lip on the outside and four bent up tabs in the middle. Technically, the angle of the gear teeth tries to push the cam gear towards the engine, not towards the radiator, but the thrust washer helps to ensure this and reduce any chatter. Many engines are missing this washer and run just fine but i searched for one anyway because something just doesn't feel right to me about leaving parts out of an engine that were designed to be in there in the first place.
Jeb
Jeb2N
09-26-2005 07:56:46
Jeb
Dell (WA)
09-26-2005 07:56:16
Roger..... .don't panic. Yer squarecan frontmount distributor keeps yer cam in place..... ...Dell
