It's Alive!
Roscoe P. Coltr
09-26-2005 07:40:03
Finally, after repeatedly (3 times) removing the distributor, inspecting, replacing and a new key switch - I put new points in a second time. This time, the ammeter was really jumping when it turned over! then...SUCCESS! Grandpa's (Roscoe)9n was running again after about 5 years of sitting. It fires right up now. I had to go out a half dozen times this weekend just to fire it up. I have the rear wheels off getting new tires and rims so I couldn't run her around the yard yet. Lots of work to do though. Grandpa put a voltage regulator on it and just cut the wires to the cut out. I've seen Dell's post on this and ordered a new harness, the cut out, new resistor (his wiring job didn't match the diagrams), plus a carb kit and the works. I know the distributor well and am learning the other electrical wiring. I'm sure you'll see me around as I try and tackle the rest. I'm no mechanic, but I am determined. Thanks for everyone's help.
Jim in North Carolina
09-26-2005 08:51:01
 Re: It's Alive! in reply to Roscoe P. Coltrain, 09-26-2005 07:40:03
You're ruined now..., great to have another enthusiast on board! Just wait till you go wheels down and see what these old machines can do while you have fun.
FarmerDawn
09-26-2005 08:17:52
CONGRATULATIONS!! Whoo-hooo!!!!!
