Battery Drain
Bama Fan
09-28-2005 05:23:21
I have an 8N with a 12 volt system. I have to pull the battery cable each time I turn off the engine or it will kill the battery. Is there a fix for this?
GAJIM
09-28-2005 07:58:45
 Re: Battery Drain in reply to Bama Fan, 09-28-2005 05:23:21
Bama Fan...I had the same probelm with my '52 8N with a 12 volt Delco 10-SI conversion. It turned out that the previous owner wired it worng when they did the conversion. Once it was wired correctly, the battery drain problem stopped. GA Jim, the GEORGIA FAN. :-)
Bob
09-28-2005 07:47:21
If your 12-Volt conversion is typical, and uses a standard Delco internally-regulated alternator, there will be three connections to it... the heavy-gauge output wire connected to the insulated stud, an smaller wire from the output stud jumper over to the terminal labeled "2", and a "switched excite" wire to the #1 terminal.
The wiring to the #1 terminal is likely the culprit here. The #1 terminal must be fed power while the ignition switch is on, and have NO power to it when the tractor is shut down. If it is mis-wired, and powered even at shutdown, the battery will be drained.
Check with a voltmeter, or simply disconnect the wire from the #1 terminal at shutdown, leave the tractor sit for the length of time it has been taking to drain the battery, and then try to start it, to see if the current drain has been eliminated.
If disconnecting the lead stops the battery drain, you need to figure out how to rewire the system correctly so power is shut off the the #1 "excite" terminal when the tractor is shut down. An "idiot light", diode or resistor is required in that lead. Post back if you need help with that.
If it still drains the battery with the lead disconnected, charge the battery back up, and disconnect ALL THREE of the alternator's wires, an insulate the with a few wraps of electrical tape to eliminate the possibility of them shorting out against metal. If the battery now stays up, the alternator is bad internally. If the battery stills goes dead, you have a short somewhere else, or a bad battery.
souNdguy
09-28-2005 06:46:02
Ditto waht old said. depending on your wireing.. there may be a bad vr / diode trio.. or could be that the excitement is staying on.. or some other component is staying energized.
Remove your bat cable, and install a low wattage lamp in line with it. If it lights up, you are in business.. it indicates current flow.
Now.. start digging around in your wireing and work from the end back.. that is. disconnect and mark 1 wire at a time till your lamp goes out. When you hit the wire that makes the lamp go out.. that wire is the one drawing the current. check it's destination.. etc.
Soundguy
old
09-28-2005 06:13:46
Yes but your problem could be a good number of things. You may have a short in a wire some where. Or the alternator maybe wired wrong. Really need more info to know for sure how to tell you the fix
