Order Ford 8N Parts Online
8n starter
8n starter prob
09-29-2005 08:55:36
The bendix gear on 8n broke and fell into clutch housing. I tried fishing it out with no luck. Is there any easy way to get it out? Does removing the steering box allow access to the clutch housing? Thanks.
Carl S in NH
09-29-2005 14:31:18
 Re: 8n starter in reply to 8n starter problems, 09-29-2005 08:55:36
That bendix will do no harm in the bell housing. Believe me, I know, because there's one rolling around in mine right now! It's been there now for a while with no problems, and my property has some steep hills that my tractor has to negotiate, so it won't be an issue. I tried to fish it out with one of those retriever magnets on a stick. It would latch onto it but wouldn't bring it up past the flywheel. Just let it stay there until the next time you have to split the tractor for something.
Carl S.
WiCraig
09-29-2005 13:54:05
Ditto on Dell's comment. Unless you are jumping hills during a motto cross with your N, no problem. And that clutch style bendix is worth the extra money.
Dell (WA)
09-29-2005 09:23:10
Neubie..... ..Would you believe Ford specifically designed the clutch housing as a starter bendex spareparts storage? No? Well, it does. There's lotta N's carrying bendix parts down there and ain't hurtin' nuttin. Bottom line, don't worry.
And recommend the new and improved "clutch" style replacement starter drive..... ..Dell
Arizona Harley
10-12-2005 02:56:35
 Re: 8n starter in reply to Dell (WA), 09-29-2005 09:23:10
Just curious,where can I get some info.on the "clutch"style replacement starter drive?
