(N rear Axle assmy. Part No: S.18516
9N Roy
10-01-2005 13:09:45
Hi,
Just start working on a 9N 1940 model. Got her runing thanks to this forum.
Rear axle seal bad, for sure. An I would guess the bearing are in need of replacing.
Question1: should I order this Part No: S.18516 which is an assebly for therear axle and bearing.
Question 2: now that I have the axles out what else should I do/need to complete this work?
Thanks,
9N roy from NC
murn-ga
10-01-2005 13:40:16
 Re: (N rear Axle assmy. Part No: S.18516 in reply to 9N Roy, 10-01-2005 13:09:45
Roy, I'm curious. Where did you get a part number S.18516 for axle assy. All you need is seal,brg retainer and possibly brg. Also will need a shop to remove and install brg. A good idea to also use a Sur-Seal.
Hobo,NC
10-02-2005 09:22:49
 Re: (N rear Axle assmy. Part No: S.18516 in reply to murn-ga, 10-01-2005 13:40:16
S.18516 izz a Sparex # fer the rear wheel bearing and race. Agree he also needs a sure seal
murn-ga
10-02-2005 09:55:49
 Re: (N rear Axle assmy. Part No: S.18516 in reply to Hobo,NC, 10-02-2005 09:22:49
Sorry, I mis-read the question. I do reconize the number as a Sparex number now.
9n Roy
10-02-2005 16:08:03
 Re: (N rear Axle assmy. Part No: S.18516 in reply to murn-ga, 10-02-2005 09:55:49
DO you have the part number for the sur-seal.
I cannot loacte this item.
thanks
murn-ga
10-03-2005 09:31:41
 Re: (N rear Axle assmy. Part No: S.18516 in reply to 9n Roy, 10-02-2005 16:08:03
This is aftermarket item. From Tisco the number for a pair is SS 92, if I remember correctly.
