Ok.. 9n and 2n have draft control hyds.. not position control. Though your lift is a bit out of adjustment ( or has a worn cam folower pin ) it's operation is -almost- normal.. that is.. the hytrol handle is setting draft.. and all the way up/back is transport mode. As someone esle said erlier today.. Henry / harry designed that tractor to have a plow hanging back there.. probably not a mower. That is also why the position is never the same on the lift. Common way around this is to get check chains.. lift mower for transport.. set chains.. relaxe lift. Then re-set for mow height... mower always drops to the same point after yuo lift it, due to the chains limiting travel depth. The leakdown is most likely a worn leaky hyds lift cyl / piston. Pull the round dipstick cover and look in with lift up under load.. if oil is running from the mouth of the cyl.. the top cover needs rebuilding. Occasionally there is a leak at the top or bottom cover gasket, or the standpipe, or from the relief valve in the pump.. mostly it is the lift cover though. Lift cover R&R is pretty easy and straight forward. Get a I&T fo4 manual. Mostly it is disconnecting control valve, pulling top cover.. hone or replace lift cyl, replace old 3 ring piston with a new naa piston and oring and washer. All gaskets, and a new piston and new relief valve come to less than 100$ add another 80-90$ if the cylinder is too hosed to use. Figure 4-5 hours start to finish to R&R the top cover, usi9ng basic hand tools.. wrench, razor blades.. cleaners.. etc. Slap in a new cam pin while the cover is off. Soundguy
