How handy are you?? If you can build things with metal, i.e. have a welder and some other metal working tools and skills, this might work for you.I think I"d start with just a 4 foot hog because of the weight, which you will probably have to double to make what I am proposing. You do not want to get too heavy, or you will have lift, etc. problems. The extra weight will be from the frame needed and the counter weight needed. A counter weight is needed because you want the implement to be balanced so that its center of gravity is directly behind the center line of the tractor - side tipping safety! So that means you must put weight out the opposite side of the tractor from the side the mower is on. Now the gear box for the mower is usually mounted with four bolts. Thus you can turn it 90 degrees so that with the mower out the side the input shaft of the mower points back to the center. Now you will need a right angle gear box to get the PTO and mower shafts to line up. I would try a differential out of a light model car. The diffy will not be one to one but that will probably be OK if you run the mower with that in mind - don"t rev up the tractor - you should not have problems with the mower running too much over rated rpms. Now that I think of it this actually this would work great with a sherman under drive where the PTO runs slower for the same engine rpm. You will need to fabricate a suitable frame to mount the mower on. I would not want to modify the mower, except for the gear box rotation, so that you can use (or sell) the mower as it was made. The top link hook up on the mower will take some thought, maybe even make the frame attachment so that it is behind the mowers top link hitch point. Don"t forget to extend the frame well to the opposite side where you can attach weight to counter balance the mowers weight. Be SURE to design the frame so that you can lift the whole unit without hitting the tires, etc. You might want to mockup the frame in wood, easier to do and cheaper, so that you can see how it works first. The wood probably would not actually lift the mower, but you could even mock up the hitch and deck of the mower out of wood too. Gee, I just thought of a fancier way to make the frame. Make it so that the mower can be extended for mowing or retracted for transport. The counter weigh would have to match the mower position for balance, but that just means making the same mechanism for both sides. The movement of each side would have to be adjusted for the relative weights of the mower and counter weight. A lighter counter weight would move further than a heavier mower would to maintain the balance. That is because of the torque each generates is a function of distance and weight. Remember your high school physics, torque is weight times distance. So the weight of the mower times the distance between its center and the center of the tractor is the torque you need to match to have the two balance ecah other. So if you can extend beyond the tractor wheels on the opposite side from the mower, you will not need as much weight out there to match the torque. Hope that will give you enough to take it from there. Larry
