Order Ford 8N Parts Online
8n hydraulics shudder when lifting a load
Rikiz
10-04-2005 13:29:26
Tried to search the archives before asking this question, but there are some gremlins somewhere that make the archives unaccessible to me. I have a 1952 8n which recently started to shudder a little when lifting a 3 pt blade. What do you suppose the problem might be? Thanks for your assistance. Rikiz
guest
10-05-2005 03:42:06
 Re: 8n hydraulics shudder when lifting a load in reply to Rikiz, 10-04-2005 13:29:26
If you havent changed the hydraulic
fluid in a long time. Do it first.
Go with 5 gal of 90 wt oil. If you
are in a cold climate you can try the light weight (20wt) 134. but the pomp
will work better with 90 wt.
Then see how the lift works.
George
Wi Craig
10-04-2005 15:29:53
Also look here, thanks to Zane. Link
WI Craig
10-04-2005 14:14:03
Go to achives above, search N site, key word "relief valve". Sounds like the problem I had. I just lived with it.
