Re: Whats the N stand for?
CWG
10-07-2005 04:56:31
The same guy who thought "N" stands for tractor, must be the same guy who put the distributor on the front!
Barry8N
10-07-2005 13:51:51
 Re: Whats the N stand for? in reply to CWG, 10-07-2005 04:56:31
Several things to think about with front mount. It was out of the way in thick brush and abuse, the original applications were engineered for areason(be it cost or design ) and it still works great 50 years later!!!
Will the new tractors be so lucky and so easy to run when computer chips burn out and are obsolete?
souNdguy
10-07-2005 06:32:38
Front mount distrib ain't so bad. front mount coil is bad. How many distribs can you pull so easilly and not worry about timing issues?
soundguy
CWG
10-07-2005 07:23:15
 Re: Whats the N stand for? in reply to souNdguy, 10-07-2005 06:32:38
I"m messing around with it right now.
The coil does seem floppy, I bent the tangs a bit to increase tension on snap down..still, I thought of using two gaskets,but the gap...
souNdguy
10-07-2005 10:28:40
 Re: Whats the N stand for? in reply to CWG, 10-07-2005 07:23:15
1 gasket should be a snug fit. my bet is the place the bail hooks is worn.. allowing play.. easy enough to verify, and if so.. adjust the bail accordingly.
Soundguy
