Engine warm up maintanence
ratropia
10-08-2005 10:59:35
49 8N.
How long and how often should I start my 8N in between regular uses? I use it for 2 hours or more, a minimum of every 20 to 30 days. Should I start and run it more often? And for how long?
Rick T.
Bruce (VA)
10-08-2005 11:04:38
 Re: Engine warm up maintanence in reply to ratropia, 10-08-2005 10:59:35
That's about how often I 'exercise' my N's in the winter; I have three, so I run one for an hour or so every week. Just make sure you are using a fuel stabilizer because otherwise you will get varnish build-up in the carb. Whenever you do start it just for 'exercise', make sure you run it long enough to get up to operating temp.
old
10-08-2005 11:02:44
You should be ok doing it that way. I have tractors that will sit for 3-6 months with out being started and have never had any problems. In the winter I only use one or 2 of my tractors and the others sit in a shed and don't get started but a few times in the winter and thats just to keep the batterys charged up.
