correct oil weights
cornflakes
10-09-2005 05:37:48
Hi, just bought a single owner ford 8n 1950. Want to change oil and filter to get ready for winter when I will be using it to push a little snow. does anyone know what is the correct and recommended oil weight to use? Thanks
PhilipIN
10-10-2005 07:46:53
 correct oil weights in reply to cornflakes, 10-09-2005 05:37:48
I have been using synthetic oil in my 8N for over ten years. I am currently using a 5W-40 diesel engine rated synthetic. 5W-40 is a good oil for winter and summer and allows me to change oil just once a year. Philip.
Bruce (VA)
10-09-2005 07:43:22
 Re: correct oil weights in reply to cornflakes, 10-09-2005 05:37:48
Lots of opinions on this one..... .here's mine. First off, when I bring a new tractor home, I put a qt of Marvel Mystery Oil in the pan & run the tractor at operating temp for an hour before I change the oil & filter. That flushes it out fairly well, and then I use 30w HD and observe the hot idle oil pressure. If the engine is worn & the hot idle oil pressure drops to 5 lbs, I'll use a higher wieght at the next oil change. These days, that means multi-vis, which I'm not too fond of in these old engines. I've got two N's using 20w50 & one, rebuilt last year, using 30w. Depending on just how cold your winters are & if you keep the tractor outside, you may need to use 20w.
