Order Ford 8N Parts Online
1949 8n
randall garner
10-10-2005 10:17:47
Well got her running but i still have carb probs. has a miss at idle but if i pull choke just a little it smooths out and runs very well, please help smells like it is running ver rich
Thanks
R.G.
Wi Craig
10-10-2005 16:20:30
 Re: 1949 8n in reply to randall garner, 10-10-2005 10:17:47
Hang in there. Had my 52n for 2 months before firguring everything out. Ran great the day before and the day I sold it. Wish I had it back. But did get $3,900 for it. As many of these posts reveal, fuel related. Craig
old
10-10-2005 10:29:44
If you need to choke it then its running lean not rich. When you choke it that makes it run even more rich. Sounds like you need to open up the main jet a little, or you have problems with a little bit of a clog in the carb
souNdguy
10-10-2005 10:52:23
 Re: 1949 8n in reply to old, 10-10-2005 10:29:44
Could also be a gasket leak, in addition to what OLD said.
Soundguy
Bill2
10-10-2005 18:43:04
 Re: 1949 8n in reply to souNdguy, 10-10-2005 10:52:23
It could also be weak spark. Mine was like that and I thought it was the carb - it only ran well with a rich mixture, more easily ignited by a weak spark. Check out the color of your spark to be sure. Del had some posts on this.
