2N stalling
A.Jones
10-15-2005 19:07:52
I have a 2N that has begun to stall after running for approx. 3-5 min. I checked to see that it is getting gas, and it is, at least to the carb.
I changed the gas filter screen, it seemed fine and the tractor stalled after the change.
Any thoughts as to why it is stalling?
thanks
art
ajones@elkcorp.com
Dell (WA)
10-15-2005 19:49:22
 Re: 2N stalling in reply to A.Jones, 10-15-2005 19:07:52
Art..... ..there are 4-common runtime issues for the frontmount 2N engine.
1) runs for about 1-min and quits; restarts in about 5-min; bad condenser
NOT yer stated problem
2) runs for about 15-min and quits; restarts in about 30-mins; bad ignition switch
NOT yer stated problem, but could be
3) runs for about 1-hr and quits; restarts after overnite cooldown; bad ignition coil
Not yer stated problem
4) runs for about 5-mins and quits; restarts in about 10-mins. sound like yer stated problem? CLOGGED fuel filters (3-ea)
There is the eazy to inspect glass-bowl filter; the i-didn't-know filter in the carburator elbow; and the SECRET hide'm circular screen filter on top of yer fuel-valve that gitts clogged with trash. You must remove the fuel valve to inspect it. It is known to "melt" and repair is by fuel-valve replacement.
First check yer fuel filter flows. Remove the 1/2" hex-plug from the bottom of yer carb and catch the gas drain in a glass mason jar. After the initial surge of drainage (float chamber) does the gas continue to flow or does it slow down to a dribble? Dribble is clogged in-the-tank fuelfilter problem..... .....HTH, Dell
( Pic ) Ken N Tx
10-16-2005 01:33:16
 Re: 2N stalling in reply to Dell (WA), 10-15-2005 19:49:22
third party image
