Order Ford 8N Parts Online
8n serial and year
R Wyler
10-16-2005 12:17:13
I posted in here before what I could make out of my serial # and 8n558533 is what it looks like though there is one numeral that is basically gone from rust I cleaned it but it is corroded away I will see if I can clean it more though. I really want to narrow down the years mine could be in is a front dist and has no tach. It also has the solid gearshiftr nob not the screw on type. When did they quite makeing the 8ns like mine?? Is there a difference in the decals for them depending on year made? Thanks. Richard
R Wyler Oh also
10-16-2005 18:11:11
 Re: 8n serial and year in reply to R Wyler, 10-16-2005 12:17:13
I was looking at John Smith's site and see the steering gear difference and mine has the old style and the one on it was wore out so I replace it with another so it must be a 49 or older. Richard
Dell (WA)
10-16-2005 16:22:28
Richard..... ....iff'n I understand you correctly, you say yer 8N engine is 4-nipple frontmount. Ford changed the 8N engine to 5-nipple slidemount at s/n 8N263844 in May 1950. And added the "proofmeter" at s/n 8N290271 in June 1950. And changed the 4-speed shifter arm to a replaceable plastic ball type at s/n 8N252844 in April 1950. The I&T FO-4 serial number listing lists s/n 8N524076 as the "last" 1952 8N and yer claiming s/n of 8N558533.
Bottom line, yer claimed s/n of 8N558533 does NOT CORRELATE with enny of yer other "mfgr clues". I'd suggest that you take 'nutter' lookie-look at yer engine s/n. You might even want to gitt down'n dirty and look underneath at yer hydraulic pump plate, sometimes there is plain date of pump mfg stamped around the right-corner pressure relief port.
Other'n "braggin' rights"; yer year of mfgr is NOT CRITICAL for most replacement parts purposes..... ..respectfully, Dell
R Wyler
10-16-2005 18:01:10
 Re: 8n serial and year in reply to Dell (WA), 10-16-2005 16:22:28
Thanks Dell I am going to look at it further I must not be seeing that # correctly it has the front dist no removeable shifter ball and no tach I will look under it and check for a date on the hyd unit. Is there any difference in decals through the years on these? I want to refurbish it this winter and install new decals also a new battery tray and grill. I wouldnt mind installing a Sherman step up/Down Combo as well sometime. I just would like to try and narrow down when it was made as best as I can. Richard
Bruce (VA)
10-16-2005 17:18:37
Dell, I've got one of the last frontmounts made, SN 262918,. The block and oil pan casting codes are identical, Feb 17, 1950 (B170) The shifter has the removable ball; the transmission casting code is Feb 9, 1950. My 1950 sidemount, with a proofmeter, SN 273657 has a block casting code of March 28, 1950, a pan code of March 22, 1950, tranny code of March 31 & pump code of March 8. With the dates you have for conversion to the sidemount, looks like assembly was running about 8-10 weeks after casting.
Dell (WA)
10-16-2005 21:31:17
 Re: 8n serial and year in reply to Bruce (VA), 10-16-2005 17:18:37
Bruce..... ...I really don't have exact production date changes of these various mid-1950's 8N changes. I just took total 1950 production, divided by 12, and linerally interpolated the change date into round months from the N-Ford Master Parts Catalog effectivity s/n listing change. Does it really matter?..... ...respectfully, Dell
R Wyler
10-16-2005 17:56:31
 Re: 8n serial and year in reply to souNdguy, 10-16-2005 14:11:28
Thanks SouNdguy mine has the front dist so I must not be seeing the # right. I will have to look for other clues it is an earlier one I know for sure. Richard
Bruce (VA)
10-16-2005 13:29:47
Google "Smiths 8N ford tractors"; you'll get all the info you need to identify the year.
R Wyler
10-16-2005 17:54:26
 Re: 8n serial and year in reply to Bruce (VA), 10-16-2005 13:29:47
Thanks Bruce I went to his site and looked at it and see several things to compare to mine and that should help me alot. Richard
