Stuck pins in clutch rod
Rick(ont)
04-18-2001 17:31:46
I need to adjust the clutch linkage in my 46 2N, but I have a problem. The pins in the clevis at either end are stuck. I've tried soaking them, but they don't seem to want to move. Should I just cut them off, and replace them?. I guess if I cut the heads off, I would have to drill out the rest. Does anyone know if replacements are available?
Thanks in advance, Rick
Duane
04-18-2001 18:36:37
 Re: Stuck pins in clutch rod in reply to Rick(ont), 04-18-2001 17:31:46
Hi Rick, before you cut them, try useing a propane torch one the nuts. cant hurt,Duane
bj/8N/mt
04-19-2001 08:03:32
 Re: Re: Stuck pins in clutch rod in reply to Duane, 04-18-2001 18:36:37
if you go at them with a torch--propane or otherwise--cherry them up then let them cool overnight. next day hit them with something like PB Blaster. Wait an hour then strike vigorously with a significant hammar and a punch. If that doesn't work them loose it is drill press time.
your mileage may vary
