worked hard put away wet
8N 270952*
10-25-2005 07:18:56
Need Help, I used my 8N Friday for about 4 and a half hrs. of heavy cutting. Went to put her up and to take the sherder off and it won't start, all I get is that long grone. The engine dosen't even turn over. I remember the noise from the old days, I just don't rembemer what the cause was. Help
Bruce (VA)
10-25-2005 07:32:47
 Re: worked hard put away wet in reply to 8N 270952*, 10-25-2005 07:18:56
If the engine will not turn over at all, the probablities are: dead/weak/bad battery, poor battery cable connections, frayed/worn/too small cables or a bad solinoid or starter. Try charging the battery before you do anything else.
8N 270952 *
10-25-2005 07:41:39
 Re: worked hard put away wet in reply to Bruce (VA), 10-25-2005 07:32:47
That where I recall that noise, it's from my mother old 1956 dodge, that my brother and I cut or teeth on. My 8N reminds me of it a lot. Before I forget as in all posting, Thanks in advance Guy's. I cleaned my posts, but I think my battery is a gonner.
souNdguy
10-25-2005 07:40:51
When you say groan.. sounds like the starter spins but bendix does not spin in.
possible causes are a dirty shaft.. or a weak battery not spinning up fast enough.. or broke bendix..
Soundguy
BrianS NE
10-25-2005 09:00:41
 Re: worked hard put away wet in reply to souNdguy, 10-25-2005 07:40:51
SouNdguy, how'd you come out with the weather?
Brian S, NE
'48 8N 60896
Brian S, NE
10-25-2005 09:06:25
 Re: worked hard put away wet in reply to BrianS NE, 10-25-2005 09:00:41
Missed the note below. Glad to hear everything is good.
Brian S, NE
'48 8N 60896
