Hey Dan, Thats funny, I had Derek send me two extra rivets also for the same reason. 1) I got the original rivets out by grinding the heads off the back side of the bumper and driving them out with a combination of a pin punch and just beating the bumper silly until it came apart. 2) I was lucky in that the big thick center bar was straight (well curved like it was supposed to be). In any event it didn't need any fixin. The other three bars were pretty bad and I wasn't sure I could fix them. It took about three nights of heating each deformed area with oxy/acetylene torch and beating it over an anvil, stump, and between two 2 by fours with a 3 lb hammer. I also c-clamped the bars to the base of my engine hoist and used heat and a piece of water pipe as a cheater bar to un-twist the twisted areas. Basically heat the bars up as hot as you can stand and beat the tar out of em. The vertical horns were aslo bent but they straighten out pretty easy with heat and the bfh. 3) To put the new rivets in I clamped each bar in place one at a time and stuck the rivet in from the front. I used my anvil as a bucking bar by propping the bumper up on top of my anvil with the rivet head resting in the top of the pritchel hole. I made a rivet setting tool out of a 3/4 inch grade 8 bolt by grinding a half round in the end of it with a die grinder. Then I just heated the rivet stub on the back side of the bumper with the torch till cherry red and set it with 4 or 5 blows. 4) See # 3. Anvil = bucking bar, Rivet Set = Ho-made from bolt, Heat and hammer. I had the bumper propped against the stump to hold the rivet upright on the anvil but a teenage boy would do just as well. My boys are 2 yrs old and 3 months old and Mrs. Flathead won't let me use them for such worthwhile activities yet. 5) No the replacement rivets are only round on one side like the originals. If they had heads on both sides you wouldn't be able to get them through the holes. The shape on the back side is determined by the shape ground into the setting tool. The ones I took were more of a flat cylinder in shape with a bit of a crown on the back side and thats what I ended up with - with the replacements. From the front, they have the same store-bought half-round shape as the originals. I know what you mean about lying awake trying to figure this stuff out. Just go for it with a vengence. I just figured I couldn't make it any worse. Hope this helps, flathead
