Order Ford 8N Parts Online
8n exhaust manifold gasket/timing front distributo
SMA in NE
10-31-2005 17:03:19
I have a leak on the rear of the exhaust manifold. I am going to get a new gasket. Any common difficulties getting the manifold off or other things to look for when I have it off? Also is there a certain type of gasket that is better than others? How do you time a front mount distributor 8N?
Jerrycpp
11-01-2005 14:22:21
 Re: 8n exhaust manifold gasket/timing front distri in reply to SMA in NE, 10-31-2005 17:03:19
You can take the manifold to a machine shop and have it surfaced so it is once again flat and true. If you have a perfectly flat surface (granite headstone, plate glass on a flat surface or some such) or a 4x36 or larger bench sander, you can sand it down and get the same surface. It's just more work and time, but costs less. As I remember the front distributor, the slot in the cam is offset - it's impossible to get it wrong.
Jeb2N
10-31-2005 17:20:41
The exhaust port for cylinder number 4 is very bad for actually eroding away from the manifold and causing leaks there. You can try a new gasket but if it's eroded pretty good, and especially if the manifold is old and equally worn out in the same spot, it still may not seal. I think some folks have done fairly well with double gaskets, but I put some JB weld to fill in the rust pits around #4 on my engine and so far no issues at all.
Jeb
Tom in MS
10-31-2005 17:23:06
 Re: 8n exhaust manifold gasket/timing front distri in reply to Jeb2N, 10-31-2005 17:20:41
I used double gaskets and it did the trick..
Tom in MS
10-31-2005 17:18:01
Link
