Order Ford 9N Parts Online
9N-760 PTO belt drive
bajafish
11-03-2005 08:23:30
I'm sure i must be dreaming, but is there a way to get a replacement set of gears (part no. 9N-713) for the "9N-760 PTO accessory belt drive"?
The overall unit is in great shape but those gears look like 20 miles of bad road.
2fordsmike
11-03-2005 19:16:44
 Re: 9N-760 PTO belt drive in reply to bajafish, 11-03-2005 08:23:30
If you really need a good belt pulley, I suspect your best deal is to buy another one at a swap meet. Seems to me they go for $50-$75, and it will be difficult to get many new parts for that much money. Just my thought. Mike-Iowa
Tim PloughNman Daley
11-03-2005 13:15:33
Hey Bajafish-
The originals were Timken tapered roller bearings; pinions; and sun gears. I'm sure there is a replacement part. Try your local (FORD) Case/New Holland dealer. They can cross reference the old Ford part number and you might be surprised at what you'll find. hth
td
Jeb2N
11-03-2005 10:09:37
Just about anything can be made, but your easiest bet is to just buy another pulley drive and salvage the parts. Then again, you could leave it as is if you don't actually plan on using it. I only run mine for my show-cordwood saw. never actually use the saw and the gearbox clanks a little at low idle, but who cares!
jeb
souNdguy
11-03-2005 10:34:29
 Re: 9N-760 PTO belt drive in reply to Jeb2N, 11-03-2005 10:09:37
I've seen really old gearboxes filled with sawdust, grease, and a little gear oil.. just enough to 'soup' up the grease... Actually made a 'tight' smooth sounding gear box..
Amazing what you can find in old equipment!
Soundguy
StahlMaster
11-03-2005 15:23:54
 Re: 9N-760 PTO belt drive in reply to souNdguy, 11-03-2005 10:34:29
Reminds me of an old trick to quiet a bad rear end in a car. Fill the differential with banana peels. Sounds great...for awhile.
