swing arm shaft
ROY CAMPBELL
11-07-2005 08:11:52
I NEED HELP WITH MY FORD JUBLIEE .THE SHAFT THAT
THE SWING ARM MOUNTS ON TURNS ,SO I CAN'T TIGHTEN
THE NUT.THE SHAFT TURNS . ANYONE WITH ANY IDEAS ?
souNdguy
11-07-2005 08:16:02
 Re: swing arm shaft in reply to ROY CAMPBELL, 11-07-2005 08:11:52
Swing arm? Lower lift arm? If the NAA is like the 8n.. if that nut turns you have to remove an axle trumpet to get at the nut to torque to 150# or so..
If this is not what you are talking baout.. please post more than a couple lines description.
Soundguy
