NAA and Box Blade - Advise needed
Paul Schultz
11-07-2005 19:36:41
There is an ad in the local paper for a "6 ft box blade. Used once. $250"
Can a 1953 Golden Jubilee handle a 6 ft box blade?
Is $250 a good price for a 'used once' box blade?
I do realize I need to determine if this is a flimsy brand to better evaluate the price.
Paul.
Randall(AL)
11-08-2005 05:43:52
 Re: NAA and Box Blade - Advise needed in reply to Paul Schultz, 11-07-2005 19:36:41
How's the hydraulic upgrade working? I use a 5 footer in this hard red clay around my place. I think a 6 ft would probably work well smoothing drives and loose dirt and such. A box blade around here is not capable of doing much packed dirt moving. It will but is time consuming.
Paul Schultz
11-08-2005 19:29:15
 Re: NAA and Box Blade - Advise needed in reply to Randall(AL), 11-08-2005 05:43:52
Randall,
The hydraulic upgrade worked great. I've been using the front loader quite a bit over the summer.
Thanks for your help.
Paul.
lonestarjeff
11-07-2005 20:25:42
You should be fine handling the box-blade, I had my(heavy)6' box-blade on the 8N today. Your NAA has a few more horses.
When I drop the claws down it's too much for the N's traction(lots of spinning), but she does fine w/ the blade. The weight of it gets much better penetration than my angle blade.
Jeff
ericlb
11-07-2005 20:09:14
paul, the jubilee will handel a 6 footer so long as your not trying to do rip out work or scrape thru clay or rock [ the wheels will just spin] if you dont want it after you see it tell us along with what brand it is and where it is, one of us may want it ericlb
old
11-07-2005 19:42:19
First have to give you a hard time LOL which is it a NAA or a Jubalee?? Yes a NAA or Jubalee should handle it pretty good as long as you don't bite off to much at a time.
Dan
11-08-2005 04:15:05
 Re: NAA and Box Blade - Advise needed in reply to old, 11-07-2005 19:42:19
I'm sure you know old that a Ford Golden Jubilee IS and NAA...
Dan
old
11-08-2005 06:37:45
 Re: NAA and Box Blade - Advise needed in reply to Dan, 11-08-2005 04:15:05
Well thats a yes, no, and sort of. The jubalee does have a couple of things that are differant then a NAA. There just little things but an Naa and a Jub are differant. But not where it counts as fra as doing work. Engine, tranny are the same but not all the sheet metal.
Dan
11-08-2005 08:27:19
 Re: NAA and Box Blade - Advise needed in reply to old, 11-08-2005 06:37:45
Actually - the ONLY difference is the center hood badge - which will not affect the ability to lift a box blade (grin). The sheet metal is identical, the body is identical, and there are absolutely no differences in the mechanics between the tractors.
All Jubilees are NAAs, but not all NAAs are Jubilees. They only called them Jubilees for one year (1953) to commemorate the 50th anniversary of Ford. Otherwise - it is just a name, and there are no differences between the 53 NAA Jubilee and 54 NAA tractors other than the nose badge.
HTH,
Dan
old
11-08-2005 08:36:28
 Re: NAA and Box Blade - Advise needed in reply to Dan, 11-08-2005 08:27:19
I knew that LOL I was just giveing you a hard time, joking with you. And whats really bad is you can pawn a NAA off as a Jub just by putting the JUb emblem on a NAA.
Dan
11-08-2005 08:52:14
 Re: NAA and Box Blade - Advise needed in reply to old, 11-08-2005 08:36:28
I figured something must be up - you are way too knowledgable for that nonsense :-)
Dan
old
11-08-2005 09:04:32
 Re: NAA and Box Blade - Advise needed in reply to Dan, 11-08-2005 08:52:14
Well you know you have to smile/joke around a little every once in a while or life get to boreing.
Russ SoCal
11-08-2005 10:43:45
 What about......? in reply to old, 11-08-2005 09:04:32
All them 8N Jubilees we see on ebay?
R ; )
old
11-08-2005 10:48:15
 Re: What about......? in reply to Russ SoCal, 11-08-2005 10:43:45
Wouldn't know about them I never go to e-bay. But if they are there then thats a real big JOKE, or at least to who ever buys one of them.
